Chronic flats
Juan1978
Hi,
I got a Lapierre RCR500 bike basically it's a road bike with straight/flat handlebars (see pic)...they call it a "fitness" bike in France. The wheels that came with this bike are Shimano WH-R500 and tires are Michelin Lithion (1).
This is my problem : every time I ride around 30-40km I get a flat on the rear wheel. I've changed the tube many times, other times I've patched it using a patch kit... quite often the puncture is on the side of the rim. When I check the rim tape ( brand: SCHWALBLE ) everything seems nice and clean. I went to several bike shops, none could find me the root cause...I'm kind of desesperated because I can't trust my bike... Please help.
Thanks !
Juan
Are you riding under-inflated tyres and getting pinch flats ?
Take tyre off and rim tape, check for anything sharp on rim. Check tyre for anything sharp (run fingers round inside of tyre). Check rim tape and refit.
J
Juan1978
Lithion tire says I can inflate them to 102 PSI. I generally put 90-100PSI. I'm starting to believe that it's a problem with my wheel or tire. I never get a flat at my front wheel... Will check the rim without the rim tape and also the tire again. Thanks for the advice
J
Juan1978
bike shop said I should not inflated them to the maximum recommended pressure... Generally I put 90-100PSI.
Profpointy
As above poster - be very very diligent about checking the inside of tyre. Despite removing the original problem bit of glass, kept on having repeat punctures. Cursed the tyre brand - then found a slight lump inside - just a bit of canvas really - and had to bin the tyre. Same brand tyre on front's done 10000 miles plus
J
Juan1978
I just found a sharp debris stuck in the inner side of the tire, removed it using a pair of tweezers ( i dont know how it went there...hummmmm) still investigating the punctures on the rim side... thanks... :blush:
J
Juan1978
thank you very much. If I get another flat, I'll change the rim tape and tyre. I'm thinking about getting these tyres (continental ultra gatorskin). Are they really better than michelin lithion ( i mean more durable, less prone to flats ) ? My current tyres are 700x25... Will 700x28 tyres fit my wheel ?
