Clamping a carbon frame
tiredlegs
Hi all.
I`m on the look out for a workstand and have been told to steer away from `the clamping type` as I have a carbon framed bike. Any views or opinions on this. And anyone you could recommend
Cheers
You can clamp the seapost if careful.
ianrauk
Tattooed Beat Messiah
Rides Ti2
as wot Fossy said or alternatively. Get an old cheapo second hand seat post to out in the frame to clamp to.
GrasB
Nr Cambridge
I find that the post clamp type are no good when trying to put a lot of torque into things, hence why I got the Tacx Spider Team. I can easily torque down my cranks & pedals without the bike moving, something I've never managed to do with a clamp type bike stand.
Vapin' Joe
Formerly known as Smokin Joe
I use a Tacx Spider Team & very nice it is too.
+1
That's what the pro team mechanics use. If you're going to get one it's cheaper in the long run to get a good one. There is no way I would clamp a frame by the seatpost, the weight distribution is all wrong and the strain on the tube must be considerable, particularly if you are struggling with a stuck BB cup. The bike won't fold in half as soon as you clamp it in, but a few years down the line...
GrasB
Nr Cambridge
Just thinking about it, there's 1 flaw with that type of stand. You can only adjust gear indexing on the bench if the cables are top-tube or internally routed as the bike rests on the BB shell.
Vapin' Joe
I have a stand where the bike rests on the BB shell, cable adjustment is no problem as the guide keeps them clear of the stand.
GrasB
Nr Cambridge
what I find is there's enough cable/resting block interaction to knock the indexing out a touch. You get it perfect on the stand & then it's not quite right on the road.
