[QUOTE 4187070, member: 9609"]I didn't know such things existed ! I was thinking of making my own with a relay controlled by one of the 12v leads within the computer.
One question though, if you leave the computer in "Sleep" mode (i presume there is still a liitle power being used) will that still switch the periphery stuff off ? or will the periphery stuff just go off on full shut down.[/QUOTE]
The one I was thinking off doesn't appear to do it in sleep mode, only when the main unit shuts down. Which is what the one I use does, only I flick the switch.
You could of course get a switched surge protection unit(Each socket has is its own switch). Mark the one for the PC, leaving that one on. Turning the rest on/off as required. Wilko, approx £20-£25.
