cloggsy
Boardmanist
- North Yorkshire
Is it the Contour GPS camera that you can display a speedo in the camera view, or is it a different one?
Thanks in advance...
It is indeed a painThe advantage of having it built in with the camera is that is no messing around try to synch it up, assuming you start recording after getting GPS lock, as I found out the first time I tried it.
I take it that it is fairly obvious that you have GPS lock with the Contour GPS?
