l4dva
- Sunny Brum!
i see this quite a bit on you tube, how easy is it? Has anyone done it and got any advice tips?
Thanks
Thanks
Not exactly cheap either:There is a company called Brombacher that sells a 4 sped conversion that fits the standard 2 speed wheel.
It uses standard shimano cogs which are readily available (so can be changed cheaply), in 11-13-17-21T.
Give it a try.I'm not sure I understand the issue around a 21t? why would it require a frame modification?
Thanks
Is the Brombacher kit for the 2-speed SA Brompton? I doubt it.
This product is not avilable on the stock 2s hubs.
You need a hub or conversion kit that can install 4 cogs.
Still interested if anyone knows how large a sprocket the Brompton shifter can reliably do.
If you want a wide range of gears on a Brompton, you need one with a hub gear (or a dirty finger change on the front as well). clearly a hub gear adds a bit of a weight penalty
