Cr2016 Cr2025 button batteries
13 rider
leicester
I have bought a couple of blister packs of button batteries but only needed the Cr2032 so I have 4*Cr2016 and 4*Cr2025
560568
Free to first reply , not sure of the quality but good value :okay:
Will split
glasgowcyclist
Charming but somewhat feckless
Scotland
You can double up the 2016s to replace a dead 2032.
glasgowcyclist
Scotland
I confess I am not an electrician so I’m not sure. Maybe I have been lucky as I’ve gotten away with it in the small lights I’ve done it with.
BoldonLad
Not part of the Elite
South Tyneside
20 is diameter in mm and 16 is depth in 1/10th of a mm. But won't two 2016s doubled up be 6.4v - so 4 in the 'battery compartment' where you'd use 2 x 2032s would deliver a potential difference of 12.8v (as opposed to 6.4v). Will the LEDs be happy?
I have just bought a pack of these:
Amazon product ASIN B07QLZ3DGGView: https://www.amazon.co.uk/gp/product/B07QLZ3DGG/
Just give me a month or two to find my GCE "O" level Physics notes, from 1963, on connecting batteries in series and parallel, and, I should be able to answer that ;)
irw
Quadricyclist
Liverpool, UK
Connecting batteries in series (as described- ie, putting them on top of one another) will indeed double the voltage (or thereabouts), potentially damaging whatever you've put them in. Connecting batteries in parallel will provide the same voltage, but will last twice as long (or thereabouts), but would require a bit of clever wiring / Insulation between the two if you wanted them in the same compartment.
13 rider
13 rider
leicester
I’ll have them if going free. Use both types in this household.
Just pm me your address and there yours
