Andrew1971
- Northallerton
Hi All
What is the most common crank arm length for single speed.
Many thanks
Andrew
Many thanks
Andrew
and angle of attack when cornering.The biggest reason for thinking about crank length on fixed is the possibility of grounding out a pedal when going around bends. Which can be very painful, but the chance of it happening does depend a lot on bottom bracket height
The other reason is a better rpm range, especialy for a higher rpm, smaller is better. There are legal standards for the track,bottom bracket clearance is another standard, so you dont hit the ground, and might even matter more than crank arm length.The biggest reason for thinking about crank length on fixed is the possibility of grounding out a pedal when going around bends. Which can be very painful, but the chance of it happening does depend a lot on bottom bracket height
