Crank unscrewing as I ride
zimzum42
Bit of a problem with the fixie. Left crank keeps falling off.
Kept screwing it back on tight, but gave up yesterday as had to stop every few hundred yards to screw it back.
Dismantled the whole drive train and noticed the right hand crank was a bit loose too. Could this be the problem?
Also, I have a little bit of a slack chain, might this be the cause?
The threads seem fine, and the BB seems fine too.
Any ideas?
rustychisel
not a problem with the chain... "hmm, chain's a bit slack there, Zim" but could it be the wrong BB mated with cranks. IE incorrect taper? You don't say what cranks, and what BB.
1. Even so, highly likely the installing torque was too low in the first place - most are in the order of 100 ft/lbs + a big grunt. Many many people don't power them on. If so, it's impossible to tell whether any permanent damage is the result, but that might include rounding out the [square tapers]... are they square tapers on your fixed??
2. Assuming square taper, another possibility is having Campag cranks installed on Japanese taper, they vary slightly, the result is that the cranks 'bottom out' before they really get tight enough.
Proceed with caution, maybe read a bit more on sheldonbrown.com and try to work out your precise problem. Cheers.
Z
zimzum42
Sugino cranks on a Shimano square taper BB
I'll check for rounding off tonight, but I think it's ok
Am just pissed off I won't be able to go for a ride this evening as the bike's in bits and all my others are in the UK.......
fred
bad luck. by riding your bike with a loose crank and taper BB, you've streched the soft aluminium hole in the crank. It'll no longer stay tight.
you now need to replace your cranks and have them fitted properly this time.
Z
zimzum42
It's fukkin gone and done it again - and this time I had it fitted properly with a torque wrench.....
What's up?!?!?!?!?
GrahamG
Bristol
Bin the torque wrench and bollock it up tight as you can!
Z
zimzum42
Oh well, solved he problem, shimano BB was incompatible with the crank, so now have a new BB and everything seems OK......
