Cube Acid 2013 Hardtail
Okay, I've only had this bike a few months and she's just had a service. I bought her for £770 new and the only issue is a small chip where the water cage should be.
Full spec here: it is size 18
Frame
Alu Lite AMF 6061 RFR-Geometry, disc only
Fork
RockShox XC32 Solo Air, Motion Control, Poploc, 100mm
Rear Shock
n/a
Chainset
Shimano FC-M522, 42x32x24T, 175 mm, 3x10 speed, 113mm Bottom Bracket BB-ES25
Chainrings
42x32x24T
Cassette
Not Specified
Chain Device
Not Specified
Bottom Bracket
Chain
Not Specified
Front Hub
Shimano FH-RM66 Centerlock Disc
Rear Hub
Shimano HB-RM66 Centerlock Disc
Front Derailleur
Shimano Deore FD-M590-10. Downswing 34.9mm, 10-speed
Rear Derailleur
Shimano XT, RD-M781-SGSL, Shadow 10-speed
Front Brake
Shimano BR-M395 hydr. disc brake (160/160mm)
Rear Brake
Brake Levers
Not Specified
Pedals
Alu PD-971
Handlebars
Easton EA30 Lowriser Oversized, 660 mm
Stem
Easton EA30 Oversized, 31.8mm bar clamp, 8 °
Headset
FSA No.10 semi-integrated, 1 1/8 "
Grips
CUBE Performance Grip
Saddle
Scape Active 8
Seatpost
Easton EA30 31.6 * 400mm
My issue on the other hand is needing a 2nd road bike sooner than I expected and I'm putting the feelers out for anyone who might consider a swap, either for an older carbon road bike, worth the same value now as the above, or a newish aluminium. I want to use this as a trainer.
I don't really want to give up MTBing but I've had a few geometry issues with this bike whilst having issues with my knees, and if I can find a suitable road bike to swap, then I will do...
I need a 54, or a medium in road bike and, as I say, this is an 18'.
Monsieur Remings
Yatton UK
sold
