Cycle helmet grade
Bear
Is there a standard clear grading system for cycle helmets ? ... like B/S marked motorcycle lids.
I've never used one before, and is there much evidence to support there use ?
I have no interest in opening 'a can of worms', just want to be clear on what i'm trying to buy.
Appreciated
John the Monkey
Frivolous Cyclist
Crewe
Quick overview of the applicable standards here;
http://www.cyclehelmets.org/1081.html
The most readily available Snell certified helmets (ime) are made by Specialized.
MartinC
Cheltenham
+1
There's no grading system for helmets. There are various standards and Snell is generally reckoned to be the best. Specialized helmets all used to be certified to Snell B90 but now it's not so easy to find out which are - check their website and what it says on the box. What's just as important is that the helmet fits correctly. Different makes suit different shapes of head (basically round or oval). You need to try some to find a brand that fits well.
Unfortunately there aren't any clear cut statistics that show benefit from helmet use. The debate is fairly polarised into 2 camps - those that are sure that they're a good thing and those that need some evidence.
Make your own mind up about what's best for you. John's link will provide useful information and more links.
Chris James
Huddersfield
Anything to be sold in the UK must pass the EN (European Norm) standard, which is the euro equivalent of a BS.
Helmets may actually perform better than this, but are not tested beyond this. Having said that, the same helmets are sold the world over so any helmet from Giro etc will / should also conform to the US standard, which is believe is slightly more rigorous.
In practice the testing involves controlled impacts on helmets pre selected by the manufacturer, except for Snell certification, where the tester selects actually helmets on sale. However, it costs a few cents to get Snell certification and it doesn’t seem to help sales as few people take any notice of the certification that comes with a helmet, so most manufacturers don’t bother. I think only Specialized do. This doesn’t necessarily mean that Specialized helmets are safer.
As far as the second part of your question is concerned, about evidence for their use ... the search function will bring up pages of arguments.
Intuitively one might expect that helmets offer some protection, but it is limited at higher speeds due tot he increase in energy involved in the impact (increases with the square of speed - i.e. twice the speed is four times the impact energy). there is also a suspicion that helmets can impart rotational forces if they skid along the ground (especially for helmets with pronounced rear vents that looks like a ducks bum).
It is certainly true that the act of cycling confers more health benefits than the risk of cycling without a lid. So if wearing a helmet puts someone off cycling then they would be better off binning the lid.
I personally used to find helmets unpleasantly hot and sweaty. I now have a Giro Atmos, which is okay, and I wear it in the hope, rather than expectation, that it will protect me if I have a crash. Unfortunately the Atmos is quite expensive. It is almost certainly no safer than cheaper helmets - probably less safe due to the large venting area - but at least it is wearable.
HJ
Cycling in Scotland
Auld Reekie
If you really think a helmet will do you any good, then the Snell foundation list is possibly your best bet, but to be honest you are better off leaning to cycle safely and spending your money on a decent set of lights...
There is a predominantly US based website that summarises the standards here
The problem is that many helmets now are far less protective than say ten years ago.
The amount of material available to absorb energy not only lessens as the number of vents increases but also the remaining material needs to be harder to retain form and shape further decrasing the capacity to absorb.
There are also fundamental differences in the tests- For instance only Snell test "Off the shelf" (i.e. the same as you are buying)nhelmets as opposed to batches produced by the manafacturer for the test.
Finally don't get fooled by cost. If you accept that the Snell B90 /B95 is the benchmark test then the Giro Atmos at over £100 is not Snell certified whereas the Specialized Aurora at les than £30 does!
B
Bear
Thank you very much for that guys. Very interesting reading.
After spending my whole life around motorbikes (& pushbikes), i thought pushbike helmets would have been a no brainer really ... quite surprised its not a clear verdict to be honest.
Maybe i'll have a rethink on that ...
HJ
Cycling in Scotland
Auld Reekie
There is a very real diffidence in the level of protection given by a motorbike helmet and a cycle helmet, also the level of risk involved in motorbiking and cycling...
Chris James
Huddersfield
I agree fully, however I probably would find the Spesh helmet much too hot to wear. And the Atmos probably offers more protection that nowt.
Unfortunately the design requiremenst for a wearable helmet (light weight, good venting) fly in the face of those for energy absorption.
Maz
Off-topic, but does anyone know if bike shops normally sell those foam/padded inserts in helmets that stick to the velcro tabs? The forehead pad on mine has perished somewhat.
yello
back and brave
France
If you can't get any Maz, I've got a stack of the sticky type ones and can happily put some in the post for you. I reckon any LBS might be able to help you out there too.
