Arch
Married to Night Train
- Salford, UK
wel,, I opted for the Cateye long fitting kit and an Enduro 8, and it fitted nicely - just right in fact, not a lot of extra wire at all - just enough to cope with the handlebar movement when steering on full lock. Had to use a lot of shim to get the sensor and magnet close enough together, but it seems to be registering.
Just need to double check the circumference setting, the kojaks are a size not listed in the setting up sheet (20 x 1.35 - anyone know the circ off hand? I'm not bothered enough to care about distortion when I'm sitting on it), and I forgot to take a tape measure to the lock up.
And I've got an idea of how I might just get away without a rack, and make my own side pods. I've got one small rucksack that fits in the space, need to find one to match the other side. Might just manage to hold lightly packed gear for a hotel tour - providing I really can pack light. Off out now to see if I can find a suitable bag.
. Following the method suggested by Sheldon here:
3.142 x (406 + 70) = 1495 on my abacus. I'd suggest that 148cm would be nearer the actual rolling circumference, unless you pump your tires up to the max....
