Derailleurs – Science or what?
Moodyman
Been commuting on new bike for a month. Due to the expected cable-stretch, found the rear derailleur skipping. So, started fiddling with the barrel adjuster and the two Hi + Lo screws (retrospectively, I know that I shouldn’t have touched these), and after four hours last night and I gave up.
Visited Bike Doctor and similar websites this morning, and it looks like a piece of cake.
Why don’t bike shops tell you the basic elements of bike maintenance and fine tuning when you walk out with a new bike?
mr Mag00
rising member
Deepest Dorset
in the same way garages dont show you how to service your own vehicle.
Spinney
Bimbleur extraordinaire
Back up north
Cos they want you to bugger up the gears by fiddling with it yourself, and then pay them to fix it! :becool:
I did exactly the same as you when my gears needed fixing - messed it up to the point of making the bike unrideable, then went and found some videos on YouTube. Took me 10 minutes to sort it once I knew what I was doing!
Moodyman
Moodyman
Am due a first service in a couple of weeks, but I thought I'd fine tune it for this week's commutes. At least before I started messing with it, it was rideable. When I finished last night it wasn't. So caught the train this morning. So f88ked off with meself.
ianrauk
Tattooed Beat Messiah
Rides Ti2
You live and learn Moodyman.
Once you get a grasp of how they work it really is quite easy to set up.
There are some good videos on You Tube that show how.
dub-no-bass
Londoninnit
They gave me a manual with mine; noddy common problems in a thin booklet with full-on service details for every part in an attached CD.
I know what you mean though - after changing the front-ring gears on my new-ish road bike for the first time (in 4 months of ownership, hey, I've been avoiding hills up to now!), the chain now skips every seventh revolution of the pedals. I have no idea what to do to fix it, it's not in the manual, so it's back to the LBS for me :smile:
just jim
Do the job with a nice scewdriver that fits - I hate it when I chew up those little screws with a knackered old screwdriver!
goo_mason
Champion barbed-wire hurdler
Leith, Edinburgh
Sounds like you might have a stiff link in the chain - every 7th revoultion that link will be hitting the rear cassette again and causing the skip.
Midlands
If its not dangerous I never mess with the gear adjustement on the road - The best tool for adjusting the gears is a workstand - on tour if I am having problems at the end of the day I find a good tree and suspend the bike - The adjustment is easy then
- that sounds right to me
Matty
Nr Edinburgh
Having just switched to single speed for commuting duties, I've all ready forgotten what a derailleur is. The chap behind me this morning probably wishes he had less gears too after he was grinding and lurching away from every set of lights with what sounds like the same problem as OP!
