Disc brake hub offset mesurement
HorTs
Portsmouth
Does anyone know if the brake disc mounting face offset on the hub are the same (barring manufacturing tolerances) for all brands?
I.e. would the disc on a Hope hub be in the same place as a Chris King hub?
Common sense says they would be but you never know.
Loch side.
Yup, ISO standard.
Edit: However, Shimano Centre Lock is not ISO standard but proprietary, but I'm sure the position will be standard.
Deleted member 23692
I can confirm that they are - I've two sets of wheels - once centre lock and one 6 bolt and they are both interchangeable. However they usually scuff slightly when first swapped over so always end up adjusting the caliper alignment anyway
