DIY advice... kitchen flooring
MontyVeda
Since I'm on a sabbatical, I reckon it's high time i sorted my kitchen out as my winter project.
What's the cheapest/best flooring?
I used to think cork tiles were the cheap and cheerful option, but they're not as cheap as I thought/recall. Some claim to be 'ready sealed', and some are self adhesive. Any pros or cons to these?
Lino or acrylic/vinyl floor tiles are another option, but cheap probably means thin.
I've ruled out laminate because the cheap stuff is pants, and I'd end up with a good 10-15mm step due to its thickness.
I've also ruled out ceramic/stone tiles because they'll crack unless I start replacing floorboards before I lay the hardboard.
I'm trying not to spend more than £10 per square metre (but 15-20 may be more realistic)... I can confidently lay tiles and laminate, but would prefer to get someone in to lay the lino as I'm likely to make a pigs ear of it.
any advice on materials, fitting and places to buy from would be much appreciated.
rich p
ridiculous old lush
Brighton
Cork tiles are a bit 70's.
Vinyl seems to be the best option as you've ruled out most other stuff.
Fnaar
Smutmaster General
Thumberland
That could look really cool: :thumbsup:
MontyVeda
MontyVeda
cork tiles are warm underfoot, natural, eco friendly, flexible, easy for me to cut and lay... and at only £8.88psm (best price found so far)... are so far, the obvious choice.... but what do i know? hence asking you lot :smile:
Archie_tect
De Skieven Architek... aka Penfold + Horace
Northumberland
Lay 6mm ply or hardboard to get a flat base first, pinned at 300mm centres to the floor boards MV, otherwise you'll get a very uneven, lumpy floor and see every board through whatever you lay on top.
slowmotion
Quite dreadful
lost somewhere
You can get solid oak flooring for less than £20 per square metre. I'm not sure how you lay it though. Whatever you choose, a slight step due to the thickness of the flooring is no real problem. We have limestone flooring which gives a 20mm step and we don't notice it at all.
MontyVeda
MontyVeda
yes that is a consideration... I've only seen 3mm hardboard though, does it come thicker?
ps. I also know to dampen it before laying to avoid bubbling when humidity is high.
Archie_tect
Northumberland
Sorry, yes should have said 6mm ply, or standard hardboard sheets [didn't know they were 3mm!]... :thumbsup: good idea to store them in the room for a few days if they have been stored in a cold, dry warehouse to let the RH and temperature balance up.
+ if laying cork tiles you could always seal the surface of the ply or h/board by painting with watered down pva.
We got the tiler to fix an 8mm aluminium angle 6mm off the ply finish to act as a shadow gap so when we fitted the vinyl sheet it slid into the shadow gap space so you don't see the cut sdge of the vinyl and it's really neat.... but you can do this with any flooring- just adjust the height of the gap to suit the flooring thickness.
