Following on from my previous header tank question. I now seemed to have cured the leak but there's a bit of damp about on a few walls so I was going to switch on the heating.
However to drain the header tank I had to drain through the hot water taps as the cold all seem to be mains fed, even upstairs. So I've almost certainly drained the immersion heater as well.
Now it's a bit of an old system and the timer just seems to be for both central heating and hot water i.e. both at once, no split. So if the hot water tank has no water in can I still put the central heating on? I suppose I could partially refill the system without completely filling the header tank but I'd prefer not too.
