DIY: Why is this wired thusly?
Tin Pot
So, a number of jobs done (bathroom light fitted and wired properly, bathroom light pull thingy refitted, upstairs bedroom light traced to loose wiring - made good, other bedroom light fitting checked all good and was the wrong type bulb for the dimmer).
Now we come to the crux of my concerns with the wiring, this is wired I believe to be always live at the fitting - why would they do this?
Could it be something to do with other fittings upstairs being in series?
The live reds have been wired together as have the Earth wires.
The black wires appear to carry no charge, when tested with an electricians screwdriver (volt meter has gone missing)
subaqua
What’s the point
Leytonstone
Switch power off
Put reds where blacks are and blacks in connector . Earths need sleeving with green and yellow.
That switches neutral only as it currently is which is prohibited by wiring regs.
Steve MIET
jonny jeez
Is that all a bit illegal these days?
Dont you require a qualified spark to sign off the work that a DIYer has done?
Loch side.
Switch power off
Steve MIET
I've often wondered about that. Surely by sleeving (i.e. insulating) the earth wire you reduce its chance of doing what it is supposed to do - be there when an errant live wire can touch something. By leaving it naked it is more "available" to redirect current and activate the earth leakage detector?
subaqua
What’s the point
Leytonstone
No as it's more likely to press against and eventually dig in then go pop . The technical reasons go to many thousands of words I have given the broad brush .
And yes any bathroom work is part P notifiable.
Tin Pot
Tin Pot
Switch power off
Steve MIET
Yes, that would be the plan but before executing I'm wondering why they did it like this.
Usually there is a reason, however poor, so I'd like to figure it out before making changes and finding something else doesn't work.
U
User33236
Have you checked the other end on the cable to see if it's wired correctly? Wouldn't be the first time I've come across black and red being mis-wired so black is live and red neutral.
Frightens me some of the bad wiring you see - hence we won't touch my mother in laws house as my FIL was always upto bodging stuff (if there was a short cut he would do it). My wife remembers where he would plug bear wires into a socket with a plug on top just because he wouldn't use an extension !! Even the Sky installation has a bodge to allow the signal in another room (without the multi-room).
The only thing I've found at home was the oven and electric shower labelled wrongly on the consumer box. Fortunately I double checked before I removed the old shower and fitted a new one. Yes it should really have been signed off by a leccy, but I'm not moving and I am careful and have wired in stuff before.
Tin Pot
Tin Pot
Yes, and no it's as it appears.
The black wires appear to carry no charge, when tested with an electricians screwdriver.
[QUOTE 4739976, member: 9609"]Does the switch work, as is it successfully switching something on and off ? and if it is, is the load side still live when switched off ? pretty dangerous if it is. The switch should cut the live side not the neutral, I woud guess an electrician would be making sure the red is live before switching them over.[/QUOTE]
Yes it works, the red at the rosette is live regardless of the switch, neither of the blacks at the switch are live.
So apart from agreeing that it's a travesty can anyone think of a reason someone would choose to do this?
subaqua
What’s the point
Leytonstone
Politely - no understanding of the wiring regs
Impolitely - farking cowboy .
