smokeysmoo
- Bolton, not very far from Nob End
Ok, the frame for my winter build arrived back from paint yesterday afternoon, and I started the build last night. I've fitted the headset, forks, bars, stem, shifters, bb/chainset, and mechs, happy days.
Then when I came to fit the brakes I had to drill the forks and the rear bridge to accomodate the bolt/sleeve of rmodern brakes, (no big deal, oh yes the brakes are Campag Veloce), now it seesm that the calipers are a touch too short! I've adjusted the blocks as low as they go, but one side still looks like it will catch the tyre, (I'll take a pic later if it helps).
I suspect I need 57mm drop calipers, such as THESE from Ribble, or THESE from High on Bikes. I know this may seem obvious but I don't want to get the wrong ones, and my concern is these may be too long as the Campag ones don't seem to be out by very much, (could I get away with filing them out a bit?).
How do you measure the drop on calipers? It's not something I've ever had to consider, the last resto/re-build I did I overhauled the original calipers so it wasn't a problem.
Ok I'm aware I'm probably waffling now, but it is 6 am and my brain isn't fully engaged
Last thing, does anyone know anywhere around Manchester that I could get long reach calipers, (if indeed that's what I need), and off the shelf on a Sunday?
[EDIT] PS: they must be black calipers too
