Drivetrain noise.
Hi, well the drivetrain on my bike seemed abit crappy sounding today, so I cleaned it all, and it's running abit better, but when I put power down and dont just cycle steady it's like the drivetrain is making a sort of sweaky clicky ish sound, hard to explain really.
Any ideas?
Thanks
Will.
MajorMantra
Edinburgh
Is there any play in your BB? Are your cranks properly tightened on?
Matthew
OLDSHUNTER
glesga
:becool:Dry or worn jockey wheel's or slight adjustment on chain/gear alingment .Try getting some oil into center of jockey wheel's check gear mech hanger ain't loose .:biggrin::becool:
maybe's i maybe's naw have a check you never no
Have a check on the individual sprockets of the cassette and make sure there is no play due to wear or insufficient locking of the cassette.
TF2............kinnell..............
Use something proper...... Finish Line Dry, Pro, and loads of proper stuff...
TF2....that's carp..... it is actually messy.........
I always grease my jockey wheels - ceramic or not..........- could be them.............
I have some Finish Line Dry, use this to clean the chain? I lube the chain with Finish Line Wet, I used TF2 to get the dirt off and my chain comes out all shiny, allthough I get like thin squares of dirt on the inside of the links and cant seem to get them off.
