Electric guitar - string help!
ScotiaLass
Middle Earth
I've played acoustic guitar for years.
For my 50th I was gifted an Epiphone Gold Top - one of these...
It's lovely guitar to play and I want to learn how to play it as it should be played - I'm still very much stuck in acoustic mode!
Anyway, I like Dunlop strings and am looking for some for this guitar. I tend to use light strings (9's) but suspect the factory fitted ones are maybe 10/11's.
I am a bit confused (easily done!) about the description of the strings I'm looking at...
"Good string to string balance from a low tension string with a smooth tactile feel that breaks in fast and last a long time".
What does 'low tension' mean? Do I want those? I've never seen that term before, but then I've never had much to do with electric guitars really!
machew
High Tension strings are harder to press on the fingerboard than Low Tension strings, although you may not notice this extra force when you play. Thus your hands get tired faster.
ScotiaLass
ScotiaLass
Middle Earth
Ah! Makes sense.
The guitar is a dream to play - very fast and light. Mind you, I'm used to 6 and 12 string acoustics :laugh:
andyfraser
Bristol
I found that choosing strings is trial and error. I've tried every major brand in several gauges over the years.
These days I tend to prefer 9s for lead and my Floyd Rose equipped guitars are set up for 9s now anyway. I've been using D'Addario EXL120 (nickel wound, 9 - 42) strings for over 15 years now and find them perfect for what I want.
raleighnut
It is probably set for 10s as standard but you should be able to get away with 9s without having the bridge reset.
Best thing to do is play it for a year or so and keep it in tune and stored where you'd normally keep it then take it to a Luthier and get the truss rod and bridge reset.
I'd recommend Bob Dayfield but he is in Leicester but he is also one of the best in Britain.
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
Yup, you'll deffo need strings. That's all I can contribute to this thread about strings. Although I think lots of threads make up a string..I'm confused now..is this a thread about strings, or a string made of threads......wibble:wacko:
Stephen C
As above, experiment to find what you like, there is no right or wrong! For electric guitar, sting thickness doesn't change the sound as much as for acoustic, so it is more about how it feels to play, which will in itself influence what you sound like!
Here is a video about it, which may be of interest:
View: https://youtu.be/WfCq1DnF378
GrumpyGregry
Here for rides.
tension will be a factor in how much you can bend notes. So if you wanna play the blues...
ScotiaLass
ScotiaLass
Middle Earth
If it's set for 10's then that's what I'll use.
It's set up lovely and I'd hate to change that!
Levo-Lon
I like 10's with a plain G..i always buy ernie ball strings..i cant really play but the wife says its sounds good ,whatever that is ..i just like chords ,and play about 6 well ..i just cant grasp the damn thing..
leccy are so much easier than acustic on the pinkies..
Saluki
World class procrastinator
My Epiphone Les Paul has Ernie Ball Slinkies (10s) on and it sounds just fine to me. Strat has 9s, Super Slinkies also sounds fine. Not a scooby about what is the acoustics though, they have the strings that they came with. Probably need replacing by now, the Takamine for sure, not so much on the Dove as I've not played it that much for about 18 months.
