twentysix by twentyfive
Clinging on tightly
- Over the Hill
Not sure this is on the correct forum page. Apols @Mods if I've put it in the wrong place.
Problem with single phase relay switch gear for motor start/stop. Help please.
The wood turning lathe won't turn on now. Previous problem was down to the surge capacitor failing but I've tried new ones with no joy. So I guess it might be the switch gear. So pulled it out of the housing with the following photographs taken to assist in remote diagnosis.
So I've only got as far as checking the green and red buttons. Both seem to be open circuit whether pressed in or not. From Googling I expected (rightly or wrongly) that the on switch would normally be open and the off switch would normally be on. Since neither are behaving as I thought I'm in a quandary. Am I doing something silly as I wouldn't expect both switches to fail simultaneously (or would I?).
As far as I can see the (two only) relay contacts inside are open and the two tube like things on the outside on one side (I think may be thermal fuses operated by bitmetal strip?) are closed.
So what next please - I'm at a loss.
