FNRttC toughometer
GrumpyGregry
Here for rides.
The unit of measure of tough is the 'Ditchling'
The unit of measure of compulsory walking is the 'Gurkha' and is measured using a device called a 'Gurkha Bridge'
The total output of all the back lights on a ride is measured in 'Searings'
The unit for the quantity of gravel encountered on a ride is the 'Slugwash'
The measure of bliss the 'Lonesome'
et cetera.
Tim Hall
Crawley
Will this use the same mechanism as the well-known and well-loved "Giveaf*ckometer"?
As used to determine the size of ones giveash*tosphere?
Back to the OP, anything where the contents of a bidon a rendered solid by the weather conditions, anything where the rider ends up damper than the inside of a bidon and anything where the floor of the midway cafe is deeper in water than a well filled bidon can all cause the Toughometer to twitch. All this can be negated by (a) having the right clothing and (b) riding with the Sort of People You Would Like on Your Desert Island (© hatler)
dellzeqq
pre-talced and mighty
SW2
et cetera.
I take it you've been down that recently. When you lot aren't around I descend that hill without brakes. Last week I turned the corner at the bottom, saw what remains of the road and had myself a brown trouser moment.
GrumpyGregry
Here for rides.
I rode home that way, and attacked it with gusto. Disc brakes work remarkably well.
