Midway through a LEJOG a couple of weeks back, and after a day of torrential rain, I suddenly started creaking from what I thought was the bottom bracket. It was only present when under heavy load - I.e. out of the saddle on a drag, or on a steep climb, and it felt to be when the left crank was just tipping over 12 o'clock and lasting till the bottom of the stroke.
The BB (GXP) had done the best part of 5,000 miles so I'd brought along a spare just in case, and spent 30 minutes on the carpeted floor of my Carlisle Travelodge room carefully removing the cranks, the old BB, thoroughly cleaning and regreasing everything before reassembling.
Everything started off fine the next day, and I even made it across the border before it reappeared. I tightened the bolts on the chainrings, I nipped up the spindles on my pedals, I re-torqued the front wheel skewer, and still the bugger remained.
So LEJOG ended and the bike was stripped down. Chain rings, pedal spindles, cranks, BB... etc everything degreased, cleaned, re-greased tightened etc, and then I set off to Bala with the club yesterday. First climb of note arrived and the little b*stard is STILL piping up! I dropped off the back of the group on the Old Bwlch yesterday specifically so they didn't have to listen to the raquet I was making... honestly, that WAS the reason!
I'm desperate now. What else could it possibly be? Headset and seatpost must be the only things I haven't touched, but I ruled out the seatpost because it usually only happens when I'm stood, and the noise just doesn't sound like headset.. I plan to dismantle, clean and slap copious amounts of grease in there this week anyway, just to make absolutely sure, but does anyone have any idea what I've missed or what else I could try?
