Freewheel
Punkawallah
Hi all,
Galaxy, trundling along no problems. Swapped 5 speed freewheel, which now slips only on the 14t cog despite showing no obvious wear. Chain line set up on the middle cog.
So; new chain, undid the B screw, pulled the wheel as far back on the drop-outs as it would go, tried both chainrings, still slipping.
Assuming the 14t cog is not worn, what have I missed?
figbat
Slippery scientist
Chain too long?
goldcoastjon
Hi all,
The repeated skipping despite swapping chains indicates that the FW cog is *probably* the issue: look more closely at it.
Are any of the teeth on the 14t cog bent, hook-shaped, or chipped?
Try rotating the crank v-e-r-y s-l-o-w-l-y in the highest gear (big ring in front, 14t on rear). watch the chain for skips or hops as it moves over the 14t cog.
Is the freewheel snug on the hub and not tightening down as you pedal?
Are any of the chain links tight or are any pins improperly inserted (not equally balanced side-to-side) ?
Good luck!
Punkawallah
Punkawallah
Good luck!
Thanks! The worst that can happen is I adjust the limiters and run on eight gears - the 36 tooth is the important one if I’m carrying a load :-)
I’ll take it out for a run Thursday, they put it back on the stand and give your suggestions a try.
midlife
New / old chains and freewheels dont always work. BITD we always put on a new "block and chain". The small cog is usually the culprit as the wrapround is small.
I expect a brand new freewheel to match the brand new chain would help .
Punkawallah
Punkawallah
I’d agree. But the old chain did not work when I swapped the freewheel, so tried a new chain. Replacing the old chain with the other changes in place is worth a thought, though. Thanks.
Punkawallah
Punkawallah
The freewheel could easily be knackered - i.e. more technical, the pawls could be slipping. Get a new one. Same happens with freehubs.
If the pawls were slipping, I would have slipping on all gears, no?
The last Suntour freewheel came off the line in the 80’s, mine is from the 70’s :-)
