Front wheel stolen - what do I need to buy?
You can see if Evans can source an OEM wheel from Spesh if you want to match, otherwise just check the dimensions and get a disc specific 700c wheel or a pair if cheaper. They won't be particularly expensive ones, so a pair might be an upgrade to the stock ones.
Please ensure your front wheel is locked too.
S
stevowmt
Thanks fossyant. It was, they cut through it!
Sorry to not know anything - but can you point me in the direction of what I would need? Here's what it says on the Evans website about the wheel.
Rims:
Alloy double-wall, 32h
Front Hub:
Disc, double-sealed, dual-lock nuts w/ 19mm contact side, steel axle w/ Semi RLCA steel QR
