MajorMantra
- Edinburgh
Classic Selle Italia Flite saddles, Ti rails
1 in excellent condition, minimal signs of wear - £30 posted
1 in poor aesthetic shape, but structurally sound - £6 posted
More pics of the £30 one:
Shimano 105 Octalink chainsets x 2. 53/39T, 170mm cranks, bolts included. I have two of these. They are BRAND NEW and sealed in their packaging. One is mysteriously missing a washer but any decent LBS should give you one for a smile - £30 posted each.
Shimano 600 (i.e. Ultegra level) chainset 53/42T 170mm cranks. These show some wear but are still plenty useable. Note: I had to have the LH pedal thread re-tapped because the previous owner had cross-threaded it. It is now useable but requires a gentle hand and careful tightening. There’ll be no problem using it but it is not suitable for a bike that regularly gets its pedals swapped. Hence - £14 posted.
Shimano SH-56 multi-release SPD cleats. I took these off some almost brand-new shoes that I bought (which didn’t fit their 1st owner) because I prefer single releases. They appear to be almost totally unused. I’ll include some suitable sized screws (not the originals) - £5 posted
Cinelli 1R stem, 26.4mm clamp to fit Cinelli bars, approx 140mm centre-centre extension, includes all fittings. This is the beautiful one with the hidden clamp system. Unfortunately the clamp face is damaged as you see so I can’t recommend using it as is, although it does work. The replacement part turns up on ebay from time to time however (I saw one go for £6 posted a month or two back) or you could get it from another 1R. Otherwise it’s in good shape apart from the usual insertion marks and some light marking. Seeing as this is an unusally long 1R - £11 posted
The clamp part:
Crane jersey – size SMALL for a 34-36” chest. Worn once, too big for me - £5 posted.
2 brake cables with MTB type ends. BRAND NEW and uncut - £1 with any other item.
Payment by cheque preferred, or Paypal if you pay as a gift and cover the fees. If you want something, say so here and then PM me.
Cheers,
Matthew
The clamp part:
Cheers,
Matthew
