presta
In my small brain - 2 teeth (On either front or rear) takes up 2 links of the chain. So if I add or remove 2 teeth [Rear and front respectively] and adjust the chain accordingly - nothing else ie: rear wheel position will need altering ?
No, the chain only wraps round half the sprocket, so if you add two teeth to it you need one more link. (One link being half an inch of chain.)
