ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
My old Garmin Etrex GPS has given me 8 years of faithful service, but it has been a bit iffy for the past couple of weeks. It has been slow to acquire satellite signals, has lost signal a few times, and has given some dodgy elevation readings. I couldn't get it to lock on to satellites at all yesterday and today.
I had a similar problem once about 5 or 6 years ago and did a hard reset which fixed the problem. (To do the reset you have to hold down a couple of buttons while powering it up.)
I just tried it and it worked again. The GPS loses all its settings - 12/24 hour clock, time zone, imperial/metric units selection etc. It also resets its odometer.
After the reset, leave the GPS switched on with a clear view of the sky so it can scan for satellites. It will have completely lost any idea of where it is, so it will have to start from scratch and could take (say) 10-20 minutes to start up properly. After it has found the satellites, you can switch it off and restart it and you should find that it is able to lock onto the satellites pretty quickly. (Mine took about 7 or 8 minutes from reset, and then about 25 seconds after powering it down and back up again.)
If you have a similar problem, Google [YOUR MAKE & MODEL] HARD RESET and give it a go.
