For a threaded headset, it is just the bolt at the top of the stem. If the stem hasn't been adjusted for some time, it is likely that the internals will have seized together - you may to give the bolt a gentle wack with a hammer if it won't move up and down by itself once unscrewed about 1/4", and you may need to then find something to help move the stem itself.
