When I try to change from large to small chain ring by pushing the lever there is no feel/ resistance.
If I pull the lever back to the bars and release it quickly it will kind of connect, I can then feel cable tension which will release when I move the shifter and it will work.
I can then move to large chain ring as normal but have to repeat the procedure when I change to small ring.
Feels as if internal part is faulty. The shifter is 8 months old and rarely used. Any advice. Thanks.
