Hi,
I have just brought a new frame and forks; they have come with a headset (Cane Creek IS-3). Am having a couple of issues, can any of you guys help!?
There is a lower crown race that the bearings should sit on, only thing is this appears to big for the bearings; I would expect the bearings to click into the race with a little pressure. Also, if I slide the lower crown race on the forks it is too tight to fit onto the forks (there is a stepped section at the base of the steerer where it joins the fork). However, If I slide the bearing directly onto the fork it fits with a perfect "click" when I push it home with my hand. I am wondering should I fit the lower bearing without using this lower race?
Should the bearings be pushed into the frame with a press - when I brought the frame they said that I can assemble everything by hand though now am doubtful. I asssume I could draw the bearing up when I assemble the stem on the fork steerer and use the nut to tension thing's up would this be enough?
I am keen to do this myself but do not want top mess thing's up which the LBS will need to sort it out. If I do need a press then an LBS job from the word go!
Thank you in advance for your help.
Oh - frame is a Guerciotti Khaybar HT - the forks with the frame are unbranded though appear to be made by carbon - Tech in China Steerer is Carbon with the lower "stepped" coller being of alloy.
Cheers
Russ
Cheers
Russ
