Old timer
- Norfolk, UK
You might remember I purchased two cheapo bikes? OK! the 6 speed rear mech on my bike work OK (although using the twist grip change needs a fairly strong grip)
My wifes gears are proving a problem to get the low gear as well as the high gear. It seems to boil down to the cable adjustment in the end but I really do think that the span of these cheapo gears is only just by a knats knacker ever going to get all the gears. They have stop screws to prevent the gears going beyond 1st and 6th (that`s a laugh)
Please someone correct me if I`m wrong?
I`m in two minds to just pick up a set of gears (they don`t look too expensive and she only rides occasionally so any decent make bottom end would probably do her)
Now I know I`m gonna run into fitting problems from the point of how they attach to the frame. The exisitng set have an allen bolt to a lug that protrudes just below the main axle(on the bike frame) and there is a small protrusion lug (on the gears) that falls in line with a flat spot on the mounting lug that prevents the assembly from spinning.
Does that all make sense or will you need pictures?
Now I know why pros use a frame to mount the bike on when they are working on them
Q. Is it likely that some cheap gears don`t have enough span to cover all the cogs or could it still be a set up problem?
Q. Are twist grip changers always a bit stiff?
Q. Would it be worth fitting a lever change to the handle bars for her and if so , am I likely to be able to use the exisitng cable?
HELP!!!
