Hope Mono Mini level compatibility
spence
Northants
Anyone know if a post 2007 Mini lever (HBSP191) will work as a replacement for a 2002 (HBSP94) lever?
I know the profile of the blades are different but are the fitments compatible - they look it on the exploded diags - and if the ratio between the pivot point and the piston push through the brass barrel / adjuster screw is the same.
Ta.
spence
spence
Northants
No one has an idea if they are then?????
