How can a rear mech be 8,9 or 10 speed?
Peteaud
South Somerset
I know the movement is from the shifter so the rear mech will only move as far as the shifter disctates, but what about the stops?
! have a 9 speed rear mech, but the new one says 8,9 or 10 speed. So how do you set the stops?
It must be even worse for 8 speed.
mcshroom
Bionic Subsonic
The stops are in the same positions pretty much. 9sp mechs work 8sp gears, I have that setup on two different bikes. As Shimano have changed the cable pull for 10sp MTB rear mechs, some tourers are now using 9sp rear mechs with a 10sp setup as well.
