How do you get air out of a gummed up slime tube?
Sara_H
........without making a terrible mess? I want to change the tube as I can't get air in or out and it's sat limply at around 40psi.
Mess - lots of it. Put a cloth over the tube and let the air out. WD40 should help clear the goo off the rims, but wash them thoroughly after. Tube in the bin.
I never use slime tubes.
Sara_H
Sara_H
I've decided not to use them again after this one has gone.
Sara_H
Sara_H
Why do you want to take it out? Is it no good?
I tried tyreweld (as a test) on the front tyre of my audax as it had a slow p*nct*r8 and it seems ok.
Because the valves so gummed up that I can't get air into it, meaning I'm riding around with an under inflated tyre.
classic33
Leg End Member
If it's presta, could you unscrew the valve from the core?
Beaten to it.
robgul
. . . the cost of time must be more than just buying a new tube? Slime is the Work of Stan in my view - it may/may not work - if you get too big a puncture it's pretty much irrepairable.
Rob
Drago
I used to use them very successfully on my commuters. When parking them up at any time ensure the wheels are oriented with the valves at the top.
PeteXXX
Photo Winner
Hamtun
I change the valve as and when. The tyre fitter at w*rk keeps the old ones for me when he fits a new tyre.
