andrew_s
- Gloucester
When you are cycling, you are most likely to be down in the bottom of the valley, and so just filling up out of the nearest stream is more likely to result in gut rot.ASC1951 said:Good grief, man, there is more of the stuff running off the hills there than almost anywhere on earth. I've walked all over Scotland for years, backpacking as well, and I've never needed to carry more than a few mouthfuls.
I had to carry water for a day and a half once (10L). There was a drought, and all of the streams were dry, and although there was water at the overnight campsite it wasn't drinkable
Enough of the stuff falls out of the sky when I'm there anyway
where do you think I get my water from when I'm backpacking/wild camping in the wilderness (Highlands) for up to 2 weeks a time, twice per year? I usually keep less than a litre at a time in my Platypus I don't need more, and often carry no water at all. I have enough weight on my back as it is. If it's fast flowing you're usually alright, if you're not sure just pop in a purifying tablet and leave it for a while before drinking (20 mins-ish), they're only 10p per pack in Army Surplus stores (well in my local one anyway). If you get desperate you could always drink from a clump of sphagnum moss (contains iodine) Bear Grylls style
It ought to be less of an issue cycling, even in remote areas there will still be small villages scattered around with service stations, small shops etc, big gaps between them maybe - ride faster
