How Tight
old bell
I have changed the saddle on my bike for a new one and the instructions say to tighten the bolt to 12NM. Not having a torque wrench and being cautious I have not tightened it enough, in that the saddle has moved when riding.
Can anyone let me know whether 12NM is fairly tight, very tight or as tight as I can get it, using just a regular allen key. I know the real answer is to buy a torque wrench, but it would be a case of spending maybe £50 for a tool I will probably only use once.
Archie_tect
De Skieven Architek... aka Penfold + Horace
Northumberland
Could you call into your LBS when you're next riding past and ask them to check it for you to 12Nm with their torque wrench- that would give you a feel for how much to tighten the allen screw by next time?
slowmotion
Quite dreadful
lost somewhere
Is this the bolt that fixes the rails to the seat post? If it is, you will probably need a 5mm hex key. A 5mm hex key (the L shaped ones) have a long arm that is 80 mm long. A torque of 12 Nm equates to hanging a 1.2 kg weight on the end of a metre long stick. This is equivalent to hanging a 33 pound weight on the end of the 80mm arm of the hex key.
That's tight!
O
old bell
Wow, that is tight. What you are saying is that using a 80mm long alen key I need about 15kg weight behind it, ie 33lbs.
Thanks for that.
slowmotion
Quite dreadful
lost somewhere
Thanks for that.
Yep. If the short arm of the key goes in the bolt, and the long arm is the bit that you grab, and it is 80mm long, applying a weight of about 15kg to the very end of the 80mm arm gives you a torque of 12Nm.
If you have a spring balance, you can improvise your own torque wrench!
Good luck.:thumbsup:
Herzog
Swinglish Mountain Goat
As the others have said, 12Nm is very tight. Using a regular allen key (i.e., the length of finger), you'd need to put some serious effort into getting it to 12Nm.
zacklaws
Beverley
Alembicbassman, on 16 June 2011 - 16:45:08, said:
If it moves when you sit on it it's too loose :smile:
I once thought I had my saddle tight after doing an adjustment on the road, till a bit further on going fast downhill, I hit a bump and the next thing I knew my saddle was nose up pointing verticle. All I could do was hang on like Ben Hur in his chariot till I got to the bottom
It was one of my best buys a torque wrench and it does get well used, for the bars, headset, seat post, front and rear mech, saddle etc
lulubel
Malaga, Spain
That's tight!
Very tight. I tried to undo that bolt today to move my saddle back slightly, and I couldn't shift it. The annoying thing is, I'm sure it was me who did it up!
Moderators
The Cronk
Unless it's a carbon component, there's a fair amount of room between "feckin' tight" and "FECK!!!"
Oops, still got me Mod hat on :blush:
e-rider
Banned member
South West
BBs are usually about 40+Nm which is about as tight as you can get it. Brake levers on the other hand are more like 4Nm which isn't that tight at all.
12Nm is pretty tight - just use you finger tips on the allen key but give it some!
