swee'pea99
My daughter's HP was getting flakey - slow, juddery, sometimes froze. So I downloaded softpaq manager from HP, and sure enough some of the drivers were old. So I downloaded the recommended new ones. Fine. Except that one of them was big and took a long time to install, so I left it to run while I went off and did something else.
When I got back, there was one of those 'Windows encountered an error and needs to close' messages. I checked using task manager - sure enough, nothing was running, CPU at 0%. So I shut it down. When I tried to restart it, it got as far as the HP invent screen, then stopped. And that was that.
I tried starting in safe mode. Wouldn't play. No response to 'repeatedly hitting the f8 key'. Same HP invent screen.
I tried disconnecting everything including the battery, holding the power key for 20 seconds, then trying again. Same difference.
I tried reseating the RAM. Same difference.
I had a brainwave, and replaced the hard drive with the (same model) from my old HP laptop. Same difference.
When I installed her HD in my laptop, it started up fine.
So, the laptop can't access the HD, right?
To confirm, I went into BIOS and ran the HDD self-test, expecting it to fail. But no! It ran the (Quick) test, reporting 'Test succeeded'. Then it went into the (Comprehensive) test.
Completed - screen says Test succeeded. Also Test 3 (S.M.A.R.T.) Test succeeded.
So I've gone out of BIOS, and....same difference. Powers up, gets to HP invent screen, then stops.
Decided to try reinstalling Windows from a CD. Went into BIOS and changed boot order to make 'multibay' first boot device (there is no CD option on these laptops...they call it multibay). Nothing! Nothing but nothing will persuade it to get past that damn HP invent screen.
Any suggestions gratefully received.
