Hybrid Bike - €1500 Budget
FCBarca
Looking for a modern, light & reliable hybrid/touring bike for the country side with a few criteria - Belt drive, disc brakes, lighting, rear carrier and flat handlebar. I have a short list of 6 bikes but reviews & feedback on pros/cons are difficult to identify - so was hoping some out there could weigh in or even propose alternatives I have not yet considered.
Cannondale Tesoro 1
Ghost Square Urban X7.8 AL U
Giant Anytour CS 1
Kalkhoff Endeavour 8 Trekking
Vsf Fahrradmanufaktur TX-1200
Marin Fairfax SC6 DLX ST
The Cannondale is the only one without a belt drive. The Ghost looks sharp and has a great reputation but the low profile of the handlebars & stem make me wonder if the Giant might not be ideal
roley poley
leeds
:welcome: if you want to customise your gearing after purchase a belt drive bike is not as cheep as chain check the range you need before buying
You need a hub gear, which type, Alfine SRAM or Rohloff.
Belts need a tension system, either eccentric BB or sliding rear dropouts. I suspect that the latter are better but there are several designs of each.
Stick with rear brake on the seat stay for rack compatibility.
Upper rack eyelets seem to be in some weird locations in the above examples. If you have to angle the rack stays down you lose triangulation stiffness.
FCBarca
FCBarca
If you can get the TX 1200 for your budget, buy it - as far as I can see it's a way more expensive bike than that. (I don't think that's a 1200 in your picture, is it?)
Thank you for that, I copied the wrong photo (That was the 700)
roley poley
leeds
I am not anti belt drive but I look and say what I see .You will need an engineered gap/gate in your frame for fitting and removal of the belt because you cant split a link perhaps save the money on that component for better bits elsewhere
raleighnut
Can you elaborate? What is steel territory, a brand? Surely this doesn't mean in terms of the frame made of steel?
Yes of course I mean a Steel frame, a really nice one would be about twice your budget but a decent CrMo one (something from Spa cycles or Genesis) will be far better than anything in Aluminium or Plastic.
