I accidentally deleted one of my bike cameras videos. Is it possible to recover?
Randombiker9
So bassically, when I fell off on Thursday I did record myself however later that day I accidentally deleted it when clearing up camera space. I was wondering if it’s possible to recover It? because I usually like to watch to see where I went wrong.
T.M.H.N.E.T
Northern Ireland
wafter
Oxford
Typically when something is "deleted" it's actually earmarked to be over-written and its visibility removed, but remains present until enough additional data is added to the memory to require the space occupied by the deleted file, at which point the file is over-written.
So, if you've not recorded any more since the deletion you may be able to recover the file using 3rd-party recovery software (there's probably free stuff available online). I've done this with camera images before using the recovery software supplied with the (Sandisk) CF cards used by the camera.
How likely you'll be able to do this depends on how accessible the memory is - is it built into the camera or stored on a removable, standardised memory card? If the latter you may have more luck plugging the card directly into a card reader while attempting to recovery.
Randombiker9
Randombiker9
Ok thanks I don’t think I did record since but then I cant remember unless i accidentally turned back on after getting my bike sorted in Halfords or way back home my camera only records 40 mins then overwrites and it’s a SD Card
Randombiker9
Randombiker9
Well I’ve tried too but weirdly there’s a lot of MOV videos that I can’t seem to play. Is there a reason for this? Is there anyway to get them to play
The reason that you can`t play the mov videos is probably due to your pc not having the correct codec for it, particularly if you are using windows movie player. I would download VLC as that will play anything.
https://www.videolan.org/vlc/
Donger
A.K.A. Buster Nuvverbike (componentry destroyer)
Quedgeley, Glos.
Jeez! How often do you fall off?
Randombiker9
Randombiker9
Unfortunately it just didn’t want to work in assume what happend is I left it on and it over wrote as it had after just not the actual fall off. Oh well. Lol.
