improving safety
goo_mason
Champion barbed-wire hurdler
Leith, Edinburgh
Another vote for common sense. Better trying to be more visible than invisible.
We all know that you can be lit up like a Pink Floyd lightshow and reflective enough to blind anyone without welding googles on and STILL someone will pull out on you and say "Sorry mate - I didn't see you".
If the driver doesn't look, they won't see you - that's the simple fact. Dress appropriately and light up, but always assume they've not seen you and cycle accordingly.
P
pooly1uk
Hopefully you'll stick around here. It's a friendly place, although it does get a bit heated at times.
thanks for the welcome messages, I didnt expect the reception ive received over the last day or so, funny as it was I can understand some of the replies, but I can assure you I am not "bogus" as someone has implied, but yes I will be sticking around, theres a lot of good stuff and a lot of good people on here.
Hip Priest
My front light fell off 10 miles from home the other night. Had to ride home with a extreme caution, anticipating right-hooks and whatnot. It makes sense to be well lit.
It looks a bit pikey, but I've got a BLT Fantom gaffer taped to my rear pannier rack. A Smart Lunar 25 rear light, Aldi spoke reflectors, reflective backpack and tyreflies. Tyreflies are good for sideways visibility at roundabouts and whatnot, Maplins do them.
Gaffer tape's a bit like The Force because it holds the universe together and has a dark side.
Shut Up Legs
Down Under Member
I'm with those who commented that lights are good simply because they make you more visible, and give motorists fewer excuses for SMIDSYs. As others mentioned, I also make no assumptions that others will be sensible, i.e. I commute expecting and preparing for anything to occur, and that approach has served me well for decades.
And yes, I also get irritated by cyclists who use no front and/or rear lights, or lights that just aren't bright enough, because they're not only putting themselves in danger but those around them too. Lights meeting the road safety rules standards (both in Australia and I presume in the UK) are relatively cheap to buy, unfortunately they don't always meet "weight weenie" standards. :rolleyes:
Archie_tect
De Skieven Architek... aka Penfold + Horace
Northumberland
The trouble with statistics is that half of them are made up, half of them are exaggerated for effect and half of them don't add up.
Little yellow Brompton
A dark destroyer of biscuits!
Bridgend
Reading the poorly thought-out, badly constructed, illogical arguments put forward in this thread and the wholly disproportionate, Daily Mail levels of outrage, I wonder if this shouldn't be moved to "Helmet Debates".
Just a thought...
I'm sure the OP will be drawn there soon enough, and will expect his contributions to carry more weight than those from engineers, material specialists,statisticians ,physicists or even people who test helmets. After all, its common sense, innit?
