As a few may remember a couple of years ago I bought a Civic that suffered judder / steering wheel oscillation under braking.
The disks were shafted and I assumed they'd been cooked and warped as they were right down to the wear limit. I replaced them and all was well for a few thousand miles, then the judder gradually came back. Long story short it's now on its 3rd set of disks having behaved exactly the same with each set.
Yesterday I finally pulled my finger out, had the wheels off and measured the thickness (taken with a micrometer at 8 equally-spaced points around the disk at around 10mm inboard from its outside edge) and runout (measured with a dial test indicator at approximately the same points around the disks, around 5mm inboard from the outside edge).
Driver's side:
Total thickness variation: 0.020mm
Total runout: 0.043mm
Observations: pads drag on disk somewhat while rotating, variation in friction with position of disk that doesn't nec. correspond with areas of high / low thickness or greatest area of runout.
Passenger side:
Total thickness variation: 0.078mm
Total runout: 0.130mm
Observations: disk noticeably easier and more consistant to rotate than D/side, with no perceivable variation in force required to turn.
So, on the one hand it appears that the d/side caliper might be dragging a little; although economy is decent, there's no smell and the wheel doesn't get hot so I guess this is minimal.
The p/side disk is clearly a lot less consistant, both in terms of thickness variation and most notably a significant amount of runout; making me think that this is the side that's causing the problem. Since I've been through numerous sets of disks the problem is clearly the result of something else on the car - I'm thinking the most likley culprit is a warped hub flange..
I want to get this sorted but have limited facilities so realistically any work will have to be done by a garage. The car's worth sod all and being run on a shoestring so I don't want to sink hundreds into fault-finding, but am open to the idea of paying to have a specific job done if I can be reasonably confident that it will resolve the issue..
As such I welcome the input of anyone who has anything constructive to offer based on the available evidence - thanks
Driver's side:
Passenger side:
