Is there a specific gear that you're supposed to leave Sturmey Archer hubs in when theyre not being
Chris S
Birmingham
I stored my Sturmey Archer 3-speed in my garage over winter. I deliberately left it in top gear so there would be no tension on the springs in the hub.
Yesterday I couldn't select bottom gear. I had to drip 3-In-1 down the toggle hole (it's a 1996 model with no lubrication hole) and use a pair of pliers to free everything up. It's now OK.
Is there a specific gear that you're supposed to leave Sturmey Archer hubs in when theyre not being used?
MacB
Not that I'm aware of and I would probably have done the same as you or removed the toggle chain altogether.
Davidc
Somerset UK
I haven't either. Can't get up to tyred's numbers, but years ago we put a spare wheel on my wife's bike, after it had spent over 10 years in the loft, and it just worked.
Chris S
Chris S
Birmingham
Sounds like my 'sealed for life' hub isn't as durable as the old type - the life is obviously a lot shorter!
I'll drop in some motor oil to try and keep it going.
tyred
Ireland
My guess is that the grease which is packed inside your "for life" has actually gone hard with a combination of old age and lack of use. The correct course of action is really to dismantle the hub, wash it out and re-grease it. Or drill the shell and fit an oiler.
Bornagaincyclist
Bristol
Years ago we used to leave the bike in 3rd gear to stop un-neccessary cable strech. Use to fill them up with car engine oil till it came out of the sides too.
We woz only kidz mind!
Regards Gordon
bobg
Forgive me if I've said this again, but SAE 30 is recommended for the "normal" lubrication Sturmey Archer hubs. 3 in 1 is too thin allows the pawls to rattle and engine oil is too thick and clogs them
Rohloff_Brompton_Rider
Formerly just_fixed
my bwr (brompton sa hub) 'lost' 3rd gear during winter, the oil i used just got a higher viscosity (thickened) due to the cold. now we're into double figures every-thing's working again, will have to strip it and use some thiner (& much less) oil.
