Joining a road
jonny jeez
so, this Junction?
Surely just indicate left?
Cant see a no left turn option
Milkfloat
An Peanut
Midlands
Side note> I don't see a turn restriction preventing the right turn here, although the road geometry suggests you should not do it, I would have thought a legal sign would be necessary.
Dirk
If 6 Was 9
Watchet
It's not a slip road; it's a Give Way junction, albeit at an acute angle.
If there isn't a 'No Right Turn' sign, then if a signal is required the only acceptable signal would be for a left turn.
[QUOTE 4702839, member: 76"]Yes it's this one.
MiniUser76 is learning to drive, he asked me how he should indicate here. I suggested that if he was going to indicate it should be right, as he is joining a road. His instructor said don't indicate as his intention would be obvious, but that he should indicate when joining a motorway or dual carriageway, in which situation I think his intention is even more obvious :wacko:[/QUOTE]
The trick is intention.
Motorway or dual carriageway on joining and staying in the inside lane no need to signal, but If you are intending to move into an outer lane, the signal gives other drivers notice of that intention as you join
The junction is different in different images. In one case the "central lane" is for traffic turning into your junction, and in another has a hatched "reservation"
In both cases you will stay in the lane, so no signal
:banghead:
Globalti
A left signal would be pointless and ridiculous.
If the two lanes ran parallel I would signal if there was anybody who needed to know my intention but at that junction I'd simply join if it was clear, go to "sport" on the DSG and boot it filling the air with noxious fumes.
