Just how realistic is it for me to build my own bike?
RaRa
Dorset
I've had a bit of a crazy idea that the best way to learn about bike maintenance would be to build my own from scratch. I already own a road bike and MTB but I'm totally reliant on the LBS for servicing as I know next to nothing about the mechanics and various "bits and bobs". I'm finding the thought of 100 quid for a basic service a bit steep especially when I add the OH's bikes into the mix - we could end up spending 400 quid between us!
I'd be on a fairly tight budget so would be sourcing things 2nd hand and from ebay. Current thinking is to go for a winter/audax bike set up.
So just how difficult is it? I'm not totally incapable but can be somewhat clumsy - I have punched myself in the face changing a tire before :smile:
Has anyone else had a go and emerged the other side a mechanical genius with a beautiful bike who can now take it apart and reassmble it blindfolded in under 3 minutes ?
Hampshire
It's really not difficult and would be a good way for you to learn, the Park tools site is worth a look.
You need to learn how to do quite a few things and I'd try and minimise what you need to deal with at first go.
Get a frame with forks and headset so you just need to learn how to fit what you have.
After that you need to get a major component and then build the rest of the bike around that - so if you get 9spd wheels then the rest will follow.
Good luck.
tyred
Ireland
The best thing to do is to teach yourself. It's not rocket science really. Go and pull a bike out of a skip somewhere and take it to bits and rebuild it as practice before you start on your real project.
smutchin
Cat 6 Racer
The Red Enclave
I'm not sure it would work as a money-saving exercise. Consumer prices for groupsets are considerably higher than what mass-manufacturers pay, so even if you got a decent deal on a groupset from ebay, it would probably be more expensive than buying the same groupset already fitted to a complete new bike bought from a shop.
And exactly how dirty do you want to get your hands? Jobs like fitting headsets require expensive specialist tools...
The kind of stuff that gets done on a "basic service" is all very doable youself without much in the way of specialist equipment. I reckon it would be cheaper to buy a new or second-hand complete bike and teach yourself the skills to do routine maintenance jobs as and when they need to be done by looking at the Park website or similar.
d.
Gatley
I've recently gone from having 90% off stuff done by the LBS to building/re-building my own bikes; the only thing I haven't done is fit a headset.
Youtube, park tools, this site etc. all have good advice on specific jobs, but, in my opinion, the thing that makes the difference between a nightmare job and an easy job is the right tool - I'd start with a good basic bike tool kit (I have the Edinburgh cycles one) and a set of cable cutters. DO NOT skip the cable cutters... I've mangled many a cable in the past with, pliers, tin snips, electrical cable cutters, stanley knives etc. nothing apart from proper bike cable cutters has ever worked nicely for me.
Finally; starting with separate parts is a good idea - you almost certainly won't save any money on the bike, but you will learn to save yourself servcing/part fitting costs. And if you start with separate parts you stand no danger of getting a second hand bike with seized in parts - seized in parts are a nightmare, particularly when you're not 100% sure you're doing it right. Plus when putting it together grease the threads of BB and pedals, the quill of the stem (if a quill stem), the seat post and the quick release spindles... That's my current list of things that have seized in place on me...
BrazingSaddles
Brizzle
Why should it be you? Get your OH on a course!! Check locally for short/evening courses or drop-in sessions. Failing that ask a friend - my OH has often shown mates how to sort their bikes out. And acquire more cycling buddies so they can 'donate' parts to you/swap shop....!
It's simple enough. I've built three bikes bikes now and loved every experience. I've done two full on Peugeot restoration builds, and my current commuter is a Ribble framed self build as well.
There is something extremely satisfying about looking at your own bike and knowing you built it :thumbsup:
Ian H
Ancient randonneur
I tend to buy bits and build my bikes myself.That way I get exactly what I want in set-up and components.
The last complete bike I bought was a cheap second-hand mtb. All I had to do was replace the frame.
BrazingSaddles
Brizzle
Am I allowed to be uber smug and say that I REALLY built mine? Dave Yates course last year - built (mitred/brazed etc) my commuter.....Now that's a great way to learn how a bike goes together, teamed with the fact the frame will be a perfect fit. (Yeah okay, the novelty still hasn't worn off!)
