key safes ...
Levo-Lon
I need to get a key safe for a relative this morning so home help Dr etc can get into his property.
loads on the market..the police approved ones get poor reviews ..weak locking mechanism !!
Anyone thoughts appreciated
Drago
The Urban Fringe
Local locksmith.
biggs682
Northamptonshire
we have one works well , will have a look later and see if its got any details on it
This is one we have , only trouble is neither of us can remember what the code is
Levo-Lon
Levo-Lon
Sorted at city locks.. 42 quid with new key cut..
the fitting kit is no good ,but ill fit it with bolts to a solid wood door so no screws in brick to prise off the wall.
thanks for the imput..
furball
Consider the size of the keys when looking at key safes. Mortice lock keys can be too big for some. I had this problem with the first key safe I bought. I replaced it with a Masterlock one and that did the job with either one or two keys in it. To store more than two keys l stuck the least used key on a bit of bluetack to the back of compartment.
If the key safe will be accessed by carers, consider ease of access for them including lighting as well as being as inconspicuous as
possible from the street.
Over The Hill
That looks good. I was going to post that some with the rotating numbers are a fiddle and hard to see in the dark.
A bit tricky to decide where to put it. Best in a place where there is a light but not obvious from the road.
Levo-Lon
Levo-Lon
Well its a modified case now.
i have drilled it so it will have 6mm bolts ,and raw bolt fixing and not the pointless 25mm long 2mm thick screws .
ive told him it wont stop a determined thief ..but it will stop a chancer.
at the end of the day anyone can get into his bungalow with a jemmy bar if they wanted too.
SD1
Ask home help. Council sometimes supply (charge) but normally kknow he best ones.
