Lappier Audacio 500 or 2Specialized Men's Diverge E5 (Cyndred/Tarblk)
Georgy107
Hello All,
Iam totally new to this group. So happy to be here. Straight away Could i place my first question?. I am stuck with two bikes dont know which one to go,
1) Lappier AUDACIO 500
2SPECIALIZED MEN'S DIVERGE E5 (CNDYRED/TARBLK)
Usage intented :- Endurance bike
Thanks in advance
Can you post the specifications
Also, have you test ridden them both. This is the best way to decide which bike is right for you :smile:
Are they both adventure bikes?
G
Georgy107
Thank you so much for the reply,
SPECIFICATIONS
LAPIERRE
Frame: AUDACIO SUPREME 5 ALLOY Fork : AUDAClO CARBON / ALLOY STEERER Bottom SHIMANO BB-R860 Bracket: Crank Set:
Front DerailleurSHIMANO 105 FD-R5801 L
Shimano 105 FC-5800 50-34
Rear DerailleurSHlMANO 105 RD-RSBOOGS, 11s
Shifters : SHIMANO 105 ST-5800 2x11s Chain: SHIMANO H6601 Tires : CONTINENTAL Ultra Sport 2 SL 700x25 Brake Set SHIMANO BR-R561
Head Set FSA 28 4D 1.1/8"
Handle LAPIERRE HB-CR12 40cm (XS) 42cm (S,M,L) Bar: 44cm (XL,XXL) ) VELO TAPE
Stem : LAPIERRE AS-LP2 -7° 31.8mm 90mm (XS,S) 100mm (M) 110mm (L) 120mm (XL,XXL) Seat
Post :
Saddle: SELLE ITALIA X1
Cassette SHIMANO105 H6580011s11-32T
LAPIERRE SP-3D1 27.2x350mm
Specialized E5 Premium Aluminum, Open Road
F RAME Geometry, threaded BB, 12x142mm thru-axle,f1at mount disc Specialized FACT carbon FORK tIat-mount disc, 12x100mm thru-axle FRONT WHEEL Axis Sport Disc
REAR WHEEL Axis Sport Disc
Presta valve
Espoir Sport, 60 TPI, wire FRONT TYRE bead, double BIackBeIt
protection, 700x30mm
Espoir Sport, 60 TPI, wire REAR TYRE bead, double BlackBeIt
protection, 700x30mm CRANKSET Shimano R8200 CHAINRINGS 46/34T
BOTTOM Threaded BRACKET SHIFT Shimano Clan's 2000, 8LEVERS speed FRONT Shimano Claris, braze-on DERAILLEUR REAR Shimano Claris,10ng
DERAILLEUR cage, 8-speed CASSETTE Sunrace, 8-speed, 11-34t KMC X8, 8-speed w/
CHAIN Missing Link? FRONT Tektro Mira, flat mount, BRAKE mechanical disc Tektro Mira, Hat mount, REAR BRAKE
mechanical disc
Specialized Shallow
HANDLEBARS Drop, 6061, 70x125mm, 31.8mm clamp
TAPE Specialized S~Wrap Specialized, 3D forged STEM alloy, 4-bolt, 7-degree rise Body Geometry Toupe SADDLE Sport, steel rails, 143mm
Alloy, 2-b01t clamp, 12mm
EATPOST offset, 27.2mm, ann-‘ 4-1 hardware
They're quite different - the Lapierre looks more of an out and out road bike with 25mm tyres (not v good ones for bad surfaces/weather, so you'd want to change those if riding in all weather and want puncture resistance) (can it take full mudguards)
The Specialized has disc brakes (albeit fairly low spec mechanical ones) and fatter tyres
Is this for all weathers?
Go try them and decide what you want/need, they are different looking beasts, so which is best is down to you. Components wise, ie wheels, groupset it's the Lapierre. Use in crap weather the Specialized (which will be heavier due to the discs and pretty basic wheels)
Is the cost the same?
G
Georgy107
Thank you, cost is same. The main issue that, i cannot understand Or differentiate byk spec. I have just started cycling. Its been some time im behind this, but finding its so hard to finilising.
