Laptop Help - Stumped
martint235
Dog on a bike
Welling
Ok BiL gave me his laptop to look at. Toshiba Satellite C660 was completely refusing to boot. It was giving a disc read error. I tried all the usual stuff: Windows installation disc repair tool but it wasn't having it. It wouldn't run the repair tool, it wouldn't run the full installation. So the PartedMagic tool came out and I completely reformatted the hard drive. Got rid of all partitions, set it to NTFS and installed Windows 7.
But it is soooooooo slow..... 7 minutes with the white arrow on screen as it boots but it hasn't hung, mouse pad still functioning. Any ideas? Is it a dead laptop? Should I install Linux on it and try to convince him to use it? Or should I try all the steps above and do another install?
Acyclo
Leeds
Check the S.M.A.R.T. data and try 3 cycles of Memtest86.
pubrunner
Go into Control Panel & then into Device Manager, to ensure that all the correct device drivers have been loaded. If drivers are missing, it can slow-down the system considerably as it starts up.
Windows 7 does not contain all the device drivers, for all laptops/pcs. It could be that a couple of 'minor' drivers are missing, such as for a webcam or even a modem.
JoeyB
Go on, tilt your head!
Sounds to me like the hard drive has issues, it probably failed in the first place because boot information was written to disk sectors that are corrupt / bad.
I would have tried some MBR repairs before reformatting but hey ho...
I suggest running some hard drive specific diagnostic tools, sea gate do a freebie which should highlight any issues, otherwise just run a check disk with /f and /r commands. It'll run at next reboot and attempt to remove data from corrupt areas of the disk (and mark them so data cannot be written to them again)
martint235
martint235
Dog on a bike
Welling
I was going to but couldn't get far enough to use the MBR stuff I had. I'm fairly sure that is what happened though as there was an area of disk it didn't want to give back until partedmagic did its stuff
