Fiona N said:I used shorter cranks on the Speedmachine to help with spinning and getting the pedals round on steep hills in low gear when the cadence dropped. But I've never seen the point on normal uprights - it makes the apparent gear higher, for a start.
The only place I've come across longer than usual cranks was, bizarrely, on a gym bike in Tokyo - given that most of the users are short older men (< 5'6") with shorter legs, this seemed like asking for trouble. The cranks were so much longer than normal that I noticed the difference and got off the bike to check - they must have been at least 200mm![]()
Steve Austin said:I've used long cranks of 180 for a while and it just meant i found it harder to spin freely.
I think the theory goes that if you are riding with long cranks its harder to spin so riders tend to mash the gears which is rumoured to be bad for the knees.
I don't think there is any science either way, just a lot of speculation.
That's certainly true for muscles but not for other components such as joints and ligaments. Repeated stress beyond their design limits does cause damage, irrespective of the amount of training - look no further than the knees of professional footballers, the ankles of professional dancers or the kidneys of professional cyclists.jimboalee said:What is 'bad' for any part of the body is exerting it at an intensity far above what is normal without progressing to that level gradually at the rate of physiological adaptation.
Cyclists who normally spin a short crank might get on a long crank bike and grind it up a hill. They are not trained for this sudden change in intensity, so they suffer.
ASC1951 said:or the kidneys of professional cyclists.
ASC1951 said:That's certainly true for muscles but not for other components such as joints and ligaments. Repeated stress beyond their design limits does cause damage, irrespective of the amount of training - look no further than the knees of professional footballers, the ankles of professional dancers or the kidneys of professional cyclists.
I've used cranks from 165s to 175s and haven't found any huge difference except when riding fixed on the road; then you need the extra leverage because you can't compensate by gearing down for hills.
