rogerzilla
This was a new one on me. 1982 Holdsworth frame, took it for powdercoating and, after blasting, they said there was a problem - filler under the (factory) paint. Turned out it wasn't polyester filler (aka bondo) but was metal. I thought it might be silver solder, which melts at about 600 deg C but they said they'd run the bare frame through the 180 deg C oven just to check first.
It melted. It's lead. The cheapskates used a top and down tube that had quite a few dents (nothing structural, but very unsightly) and filled the dents with metal to avoid wasting it! It's a Mistral frame, so full 531DB and presumably quite an expensive tubeset.
I got the lead out with a blowlamp and a damp cloth and am going to use body filler now. Sadly this also means a rattle-can job as even the specialist aluminium powder-enhanced alloy wheel filler is marginal at powdercoat fusing temperature.
