- South Manchester
Blimmin water leaks.
Had one a couple of months ago when a tap was left on, then found out today the inlet pipe to the loo has started leaking. Big stain on ceiling in lounge. Rushed out and got some joint seal, fixed it, then the ruddy loo wouldn't flush. Checked inside the cistern and the membrane on the flush system had split.
Back out again and upgraded the float and flush to a more modern one where you can adjust flush and it has a dual flush mode, all still using the existing handle.
Whats going to leak next......
